Thread: REAR AXLE NUT BOUND UP HELP
Created on: 03/27/15 02:07 PM
RE: REAR AXLE NUT BOUND UP HELP
04/08/15 5:28 PM
I used to go a little loose on the axle nut (as is my usual practice with most torque specs). The torque might have something to with compression on the wheel bearings or the legs of the swing arm. My rear axle nut is only is only torqued to 50 ft lbs with the Carrazzeria rim and bearings. CZ recommends using half the OEM torque spec for the rear axle.
04/09/15 5:59 AM
Don't know if this is true or not,but I have read you should reduce torque settings by as much as 25% on lubed bolts
danfzx14
danfzx14's Gravatar
04/09/15 6:37 AM
What size reusable cotter pin goes on the rear axle?
http://www.mcmaster.com/#cotter-pins/=wocwm3
* Last updated by: danfzx14 on 4/9/2015 @ 6:38 AM *
